Hello,
Could someone tell me what diameter I should order if I want to replace the 31.5mm + gasket hardlex on the 7s26-0020 case with a super dome acrylic with tension ring ?
I guess that pressing a 31.5 acrylic with the original gasket should work but it's not the way to install tension ring crystal right ?
Thanks in advance,
Olivier
Thanks in advance,
Olivier
