Seiko 6138-0011 date adjustment problem
3.6K views 1 reply 2 participants last post by  7s26b
#1 ·
Hi guys,
i received a 6138-0011 yesterday which i bought from the bay. A real nice original and clean watch but with a date adjustment problem. I disassembled it yesterday but could not remove the crown. It was stuck, i had to remove the crown from the stem to get the movement out of the case. After removing the day and date wheel i discovered a broken wheel jammed in the movement. After removing the broken wheel i could remove the stem. I turns out the be the wheel that drives the day and datewheel for manual adjustment. I want to replace this broken part and i've searched the partslist (http://goldsmithwatchworks.com/6138A.pdf) and found 803617 Setting wheel lever complete. Can anyone confirm that that is the broken part?
