Zodiac Super Seadragon (ZO3703) on a Black Leather Strap with the Zodiac Stainless Steel Buckle. The Strap is soft and secures the watch well. It is a smart looking strap that has stark white stitching around the edge of it's 24mm width.
Huge 50mm square shaped Stainless Steel Case fits very comfortably for its size (BIG). It is polished to a glossy finish. Does not poke or pinch my skin as I worried. The bottom of the case curves to fit on the wrist.
The attractive Case Back is adorned with the Sea Dragon logo and the other normal assortment of writings and numbers.
Orange Dial with enough brightness to be eye catching, but not overwhelming. The hour markers are silver with Lume that fades as time passes. I am used to being able to tell time in the early morning with my Seiko Watch's Lume. I can not make out any markers at all after the watch sits for the night. I am disappointed with the Lume.
Two Bezels. The outer Dual Time Bezel (silver with black writing) has numerous cities from around the globe that correspond to time zones for which you would set the dual time display. The Inner bezel is the traditional dive bezel (black enamel with silver numbers and markers) The Diver bezel works at it should, but would be near impossible to turn in in the water. Both bezels operate independently.
The Dual Time Window is set in the twenty four (24) hour mode. The Dual Time Zone display window is located just below the center of the dial and above the Six O'Clock position.
The hands are both attractive and functional with red accents.
Crown has the Zodiac simbal on it. Pushes in to secure for water resistance. The CROWN DOES NOT SCREW DOWN.
Date window at three (3) O'clock position. Nothing special here.
100M water resistant. Works at is should. I have had no leaks.
Swiss quartz hacking movement that has worked flawlessly. The second hand is NOT a sweep hand. It steps through each second.
Overall, I am very pleased with the timepiece. Looks, Feel, Accuracy, Reasonable Priced. I have a Stainless Steel Band and a Black Zulu strap on order to spice it up or dress it down.
