I would like to trade for a Seiko 6105 Diver, all original.
Here are the specs on the Orsa
Swiss ETA 2824-2 movement with the date at 6 o'clock. Includes the box, warranty card and the unworn rubber strap with signed buckle. It's on a bead blasted Watchadoo bracelet which alone goes for $50 and it seems to be a natural fit for this watch. I would rate the watch at a conservative 85%(TZ), It has a slight scuff on the crystal, some scuffs on the back case and some very light marks on the bezel insert. the bracelet has some wear as well.
- ETA 2824-2 , 25 jewels
- 316l Stainless steel case
- Unidirectional rotating bezel with 120 clicks
- Domed hardlex mineral crystal
- 300m/1000ft Water resistant
- 8mm Screw down crown
- Date at 4hrs
- Super luminova coated hands and dial.
- Bezel/case back polished.
- 22mm lugs with connecting rods
- Weight: 126g
- Dimentions: 45mm wide x 54mm length
- Thickness: 16mm
