Hi guys, another 7548 question. I figured I needed a new bezel gasket for the 7548-7000 I last posted about but I have bought a couple off of ebay and none of them seem to fit the watch all too loose/flimsy and just gum up when the bezel is turned, and one of them I couldnt even get to stay in the groove for the bezel it was so big. Anybody know where I can buy some good aftermarket bezel gaskets that will actually fit/work. Thank you.
Did you use silicone grease to lubricate the gasket?
If not the gasket will bind even if a good fit.
To add to this, in case you weren't aware, the gasket can need gently stretching before fitting. The 7548 tech document describes how to do this.
I get my diver gaskets from Bry so you could try messaging him (bry1975)
Discussion Starter #8
Yes, I use trident silcone grease I also have a silcone spray from them I think it works pretty good.
