Hi,
I'm attempting to repair a 7s26 movement.
The date indicator maintaining plate is attached via three slotted and one very, very small Phillips head screw.
What size Phillips head driver is needed to remove it?
I've got a 1.2mm and it's far too large.
Also, using the tiny phillips head seems like the worst idea ever.
Apologies if this is in the wrong forum.
Thanks
· Researcher
I have to confess- I'm not sure either, but others have had similar problems with finding the right tool, here's a post which may help you to modify an existing screwdriver.....http://www.suukko.com/ps/ hope it helps.
· Banned
bluloo said:
Hi,
Thanks
I've had no problems using a 0.5mm flat blade.
