Top 10 Chronograph Movements, Part 1
2.7K views 6 replies 2 participants last post by  Fastest
#1 · (Edited)
Personal Top 10 contains in-house manufactured movements as well as mass-produced movements from manufacturers such as Lemania. You will also note that I’ve included types with both column-wheel and lever mechanisms. Other considerations include aesthetics and other attributes, all based on my experience in watch collecting over the last 15 years.
1. Zenith El Primero
The El Primero was introduced in 1969 and the first two versions were Caliber 3019PHC (with chronograph and date) and Caliber 3019PHF (with triple date, moon-phase, and chronograph). This first automatic chronograph movement ever is a ‘fast ticker,’ with a frequency of 36,000 vibrations per hour (vph). Most chronographs at the time of its introduction were ticking at 18,000 vph or 21,600 vph. The 36,000 vph makes it possible to time intervals to 1/10th of a second. The El Primero movement as we know it today is an evolution of the very first Caliber 3019 movements. Over time, we’ve seen several brands other than Zenith using El Primero chronograph movements, including Movado, TAG Heuer, Ebel, and even some Rolex Daytonas (though Rolex made some adjustments to it). If you are really into chronographs, you need at least one watch with this movement inside it.
#2 ·
2. Lemania 5100
You don’t have to be a movement expert to see that this one is a rather ugly specimen. It has no column-wheel mechanism and it even has some plastic parts inside. The reason that I put this particular movement at number 2 is that it is a no-nonsense workhorse, with central second and minute chronograph hands (for easier reading), a 24-hour hand, and a day-date feature. This movement was discontinued a few years ago, which apparently brought a few chronograph collectors nearly to tears. Tutima is one of the brands that has used it for a very long time, even after the discontinuation of its production. Other brands that have used the Lemania 5100 include Omega (which calls it Caliber 1045), Sinn, Fortis, Porsche Design, and Alain Silberstein. Lemania also created its own chronograph watches in the past that contained this movement. Word is that Fortis, Sinn and Tutima used this particular movement because it was the only one at the time meeting military requirements for chronograph watches.
#3 ·
3. Lemania 2310
Another Lemania, but very different than the 5100. This Lemania 2310 is perhaps better known under Omega’s “Caliber 321? label, which was used in the very first Omega Speedmaster watches. However, Omega wasn’t the only brand to use this Lemania column-wheel chronograph caliber. Even Patek Philippe used it for some of its chronograph watches, renaming it Caliber CH27-70. Of course, the Patek Philippe CH27-70 looked very different from the Omega Caliber 321 in terms of its finish, but both are based on that very same Lemania movement. Speedmaster fans crave the original Caliber 321, which Omega replaced in 1968 with Caliber 861 (also based on a Lemania movement), which had a lever mechanism instead of a column wheel.
#4 ·
4. Rolex 4130
Before 2000, Rolex used hand-wound Valjoux Caliber 72 chronograph movements, and modified Zenith El Primero movements, for its Cosmograph Daytona watches. In 2000, Rolex introduced the successor to its Caliber 4030 movement (based on the El Primero), Rolex Caliber 4130. Fully developed and manufactured in-house, this automatic chronograph chronometer movement is solid as a rock and cleverly engineered. Rolex was able to reduce the number of components with a new, patented solution for the chronograph mechanism. The extra space has been used to house a larger mainspring, which increased the power-reserve capacity from 50 to 72 hours. A watchmaker from a local Rolex service center has also told me that the Daytona is quite easy for them to service thanks to this movement’s construction.
#5 ·
5. A. Lange & Söhne L951.6
Let’s go a bit high-end here, to end Part 1 of this list. The hand-wound Caliber L951.6 by A. Lange & Söhne powers the brand’s Datograph Auf/Ab timepiece and, as you can see from the photo, has an incredibly high level of finishing and craftsmanship. The balance bridge has that traditional Glashütte finish (hand-engraving) and all the movement parts are meticulously finished as well. All the parts — even the balance spring — are manufactured in-house. This particular movement consists of 451 parts, which means assembly is surely a painstaking job for Lange’s watchmakers in Germany. Although I have much respect and admiration for all Lange movements, the one in the Datograph Auf/Ab (Up/Down) movement is definitely one of my favorites.
#7 ·
Not to interrupt your list, but let me insert one of mine...
It's not exotic, by any means (though there is an interesting story behind its continued existence through and after the "Quartz Crisis"). It has been a part of and continues to find its way into MANY watches across varied brands and price points. It's a basic workhorse but also can be the foundation of some interesting variations, both from the original manufacturer and others. And, I have a BUNCH of them in many different quises (from $2K examples to ones of five digits); they have never let me down... the ol' venerable ETA 7750.
