1 - 19 of 19 Posts
The Making Of; the Superlative Oil filled Casio F-91W DeepSea
The humble yet iconic Casio F-91W is a pretty good watch and costing only some 12 euros it is just about impossible to beat its value for money. Small wonder it is the world´s most worn wristwatch by far.
It does have two weaker points:
  • the strap, which is prone to break over tome
    the water resistance, which is only shower proof
The first issue is easily enough solved using G-shock strap adaptors so it can be used on a ´Nato´ type woven strap.This way mounted on the strap the head does not get stressed when there is a pull on the strap and the strap itself is unbreakable.
The water resistance is a more challenging issue. There is however a solution which is as effective as simple to apply; fill the head with liquid to start with.
Since a liquid cannot be compressed simply filling the watch with liquid without any bubbles would fill it at zero pressure meaning the liquid will stay in as the seals can take thát.
Since a liquid cannot be compressed simply filling the watch with liquid would make the watch resistant to any further liquid ingress to whatever depth since it already ís 100% full.
Ok. So what liquid to use?
Oil is the simplest since it does not conduct low voltage currents and is water repellant.
Vegetable oil would be compatible with rubber and plastics.
Since the F-91W is thé campo watch worn by just about áll workers in the olive oil industry and extra virgin olive oil is the superlative vegetable oil, the choice was made; extra virgin olive oil.
A first test revealed that the quartz module would submersed in oil indeed keep funcioning as Casio intended.
It also proved to be a bit of a pain to fill it for 100%;.
The idea however proved sound as lowering into a two metres deep tank gave no problems.
Time to do it properly:
Step 1. prepare everything needed
Step 2. once prepared with a bocadillo seranito and a nice glass of Tempranillo, fill the bowl and remove the case back
Step 3. lower the head into the oil, with one side down and sssssslooooooowly inmersing it to give all the air time to rise and exit
Step 4. lower the case back, inner side up and while inmersed turn it round and put it on the back of the head, taking care not to trap any air
Step 5. put the screws back while retaining the oil
Step 6. check
Step 7. clean the watch and enjoy the Superlative oil filled F-91W
Using this olive oil has the additional advantage that the greenish colour cléarly shows that the watch is filled with it.
HC
p.s. I forgot :-[ to mention:
Because there is now no air inside, there is no refraction on the inside of the ´crystal´, so the legibility under the slightest angle has been noticeably improved. It is like the inside has the ultimate AR coating.
HC,
I took the liberty of embedding your photos- band-width isn't a concern when such pioneering horology is going on, but thanks for being mindful. I remember before I really got into watches I was taken by the idea of filling a watch with oil for water resistance (before I knew there were companies that did so), and the idea is still captivating even now, especially in such a DIY way. I will be interested to hear how well the watch contains the oil over time, do keep us informed of any changes- science depends on it! Thanks for sharing, sincerely.
You filled your watch with olive oil. Extra virgin olive oil.
I don't know if I use this smiley
or this one
Now that is just crazy cool. :bravo_2:
Love the hydro watches. I remember somebody over in the gshock forums did this too.
Great pictorial for your endeavor. EVOO, healthy tasty choice. lol.
I've read that olive oil can go rancid over time. But being sealed and all, wonder if anything would change.
I guess changing the battery would just be another go at this same process you just did.
Keep us updated. I'm tempted to try this on my Mudman.
Cheers, Dave.
Thank you guys.
As for the oil retaining it is important to get all the air out and not to overfill. Since the plastic case is flexible you can fill it to the point of bulging. When the thing warms up this will put a lot of pressure on the not so seals.
The trick is to press the middel of the caseback firmly down so you will squish the oil out.
It also helps to use temperate oil.
Do NOT use mineral oil nor anything synthetic!!! There is no way of knowing wether it is compatible with the rubbers and plastics.
I use olive oil because it is visible. I have appropriate silicon oil on the shelf but that is invisible, so nobody would believe.
Although I knéw what I was doing it remains a véry strange to experience that the light is working ;D
I have read a lot of crap about liquid filling in pressurised sealed chambers and wr ratings and this is a nice relativating illustration O:)
Bottom line however is that the F-91W now has an indestructable strap and unlimited WR rating but the best thing is that it is huge fun, functional at the price of beer money :dance:
A very original mod, but it does make changing the battery a bit messy.
Also the reason oil-filled commercial watches are filled with special mineral oils is that organic oils degrade (oxygen and bacteria) with time, they become acid and this will inevitably compromise the rubber gaskets. In your case the worst that will result is an oily wrist and a loss of a few dollars, but on a $1000 or more diver's watch under warranty, it's an absolute no-no for the manufacturer.
Here is a page with several silicon oil filled G-Shocks: http://mygshock.com/2008/10/13/g-shock-hydro-conversion-pressure-test-2/
Discussion Starter · #10 ·
Low acidity is the criterium for ´virgin´ and more virgin than virgin less acid still :)
EVOO is renowned for resistance to oxidation but that is not important since the stuff is sealed air tight without air.
To make sure it started fresh I opened a can straight from the press down the road ;)
A battery change is a once in 7 year operation and would simply incorporate an oil change. No, not more messy than the original filling which was not messy.
Remember it is vary tasty and nice smelling oil. The bocaldillo serranito and tempranillo were in the first picture for a reason.
Combine it with lunch!!!!
All you need is a chunk of bread, a piece of cheese to clean up.
Oh, and you know those vanilla scented rubber straps? My watch now has the rich bouquet of quality EVOO :dance:
Anyway, bottom line is that my F-91W ís more functional now but foremostly this topic is about having fun with watches and relativating the part of wisdom taking itself and the whole thing too seriously.
So, mod your´s tomorrow while enjoying a nice meditaerranean sunday lunch :))
Discussion Starter · #11 ·
LUW said:
And what about using liquid silicone? That wouldn't harm any plastic or rubber.
As I wrote, I have that on the shelf but it is crystal clear, so invisible whereas I wánted the greenish hue to advertise ´EVOO Inside´ :))
Also it does not make for an enjoyable lunch and is not nice smelling.
HomoCaballus said:
The bocadillo serranito and tempranillo were in the first picture for a reason.
I must say your bocadillo made me hungry! ;)
A really "fun" post and very interesting, well in a way sort of amazing and no chance of corrosion i should imagine and does/would it improve water resistance ?
ps: Your lunch does look appetising :)
Discussion Starter · #16 ·
Time said:
that's pretty impressive.
Well, thank you.
It was intended as both fun ánd solve two ´problems´.
Between brackets because a DW5600 is cheap enough more capables till, but that would not have been zero fun.
Now imagine the same sort of thinking&doing applied to a turbo diesel with in-line pump engined offroad car :57:
Discussion Starter · #17 ·
Pressing the wrong button I got a search on TheWatchSite instead of going there.
Boy, was I laughing when I saw what the third hit is....
It is still going strong btw. I have hardly worn it as the SDGA has been/is the daily beater but it was only a few seconds off when I set the DST and there is no sweat or what.
I'm working on trying this with an analog watch which has other complications. I have a very thin silicone oil I'm going to use. You mentioned that you like the bit of color the olive oil adds though. This got me thinking, what about DOT5 brake fluid? It is a silicone oil, it is dielectric, and it has a faint blue tint. Has anyone heard of this being used?
I apologize for bringing up an old-ish topic (although, despite this being a watch forum, I find this thread timeless), but I was so fascinated by what HomoCaballus did with that F91W that I went through the [rather minor] trouble of signing up for a username just to express my kudos and to ask one particular thing: how does the "microlight" performance change with this mod, if at all? Does the light diffuse in a more even manner or quite the opposite, or, perhaps, it is not affected at all? I'd love to see a photograph of your EVOO wonder with the display light on. :)
1 - 19 of 19 Posts
