1 - 20 of 52 Posts
Hi guys it was my understanding that the Sbbn017 bezels were a direct swap for a 6309-7040 . Mine is not working out that way , am I missing something ?
Thanks
well hello Cecil...i remember another member running into this..can u show some pics of the bezel?...top and bottom pics?....i think there is some difference in the years...God Bless John
This is just my luck ! Every time I try to do something it's one step forward and three steps back.
hey it is no biggie..we all learn and that is why we are all here...i am told there are a few styles of these bezels and some have a different mounting...hey can u tell me this...did the bottom of both bezels look the same?...i wonder if you have the bezel that uses that metal piece versus the click ball....i will gladly help in any way i can...God Bless Jhn
Ive just done a quick Google, the Sbbn017e has a uni directional bezel and the 6309 has a bi-directional bezel.
I would assume there would be a difference as the uni directional uses a click ring affair, and the bi directional 6309 uses a click ball and spring.
The underside of the bezel is different for each system (or at least it is on the bi directional 7002 bezel's and the later unidirectional 7002/skx bezels).
Modification of the bezel may well be required.
Hey Ivor...can that be modified to work?....that would be great if it could be....i wonder how many other model bezels will fit the 6309...God Bless John
well i think that is the other style...take a look at the 6309 bezel you have....you will see the difference....they have a different click setup....i think that one has that funny looking metal spacer under the bezel...
hey how does it feel when you try and install it?...will it push down and just spin around?...will it stay on?..
hey no new pics...
well i think the mating surfaces are made for different styles...and with that being said...you have the later style that does not use the click ball....so just to be clear.....it will not snap on and stay put?...you can pull it off with some effort
Well that is a beautiful bezel...i have been looking for one myself to complete my TST...i did not realize they were not compatible either...i wonder if it can be modified to work...and what you will need to make it work...if the bezel can be machined or will it need case modification.....someone who has ran into this i am sure will chime in....
hey i just thought of this too...will the old bezel work fine?...no problems with it?....functions as it should?...
hey look at the back of this 6309 bezel....
1 - 20 of 52 Posts
