Some pictures could help
Post a couple pictures and someone will answer.
Please share more about removing the bezel. Thanks!The bezel is an easy fix .
Simply remove it (i always use a sharpened credit card) - clean the bezel and case up.
Relube using silicon grease and reassemble. Should do it.
Is it not working? Have you tried the reset procedure for these? I have quite a few of these movements and a certain % do not immediately restart after a battery replacement
