Both very much of a muchness but which would you choose if you was going to buy one and why ?
I don't think I'd ever buy either (for "close" to the same coin, I'd buy an original), but that's me. The bezel on those things are so TALL. To answer your question, I'd go 025 between the two. =)
Yep, that tall bezel plus the case is thicker and larger than the original, it's an ugly reinterpretation. Top view looks fine and the high-beat movement is appealing but upon overall aesthetic inspection I decided to pass.>QUOTE]
the only bracelet that I've seen for these is a modified MM300 bracelet. The end pieces were slightly shaved to fit and it looked great; that would have your ratcheting extension too.Gents, I know this is an old thread, but am in the exact same position.
Apart from the Everbrilliant steel on the 039 (which I do prefer) is the same all equal?
I like me a good bracelet, unlike many, I especially like the ratcheting extension on Seiko's pro diver's since I use my watches diving in anger. What is your preferred bracelet on these watches? Thank you!
I went with the Uncle Seiko Beads of Rice with retrofitted Omega Speedmaster end links.Gents, I know this is an old thread, but am in the exact same position.
Beautiful watch and the bracelet suits it, looks vintage. Care to share your opinion on how this watch wears compared to the MM 300 (SBDX001, SBDX017 etc.)?I went with the Uncle Seiko Beads of Rice with retrofitted Omega Speedmaster end links.
Yes the SLA025 is larger because it is taller by about 1.4mm and has a decidedly heavier watch head so it is bordering on a top heavy watch. Not that it is an issue, whereas the MM300 is not at all.Beautiful watch and the bracelet suits it, looks vintage. Care to share your opinion on how this watch wears compared to the MM 300 (SBDX001, SBDX017 etc.)?
Does it wear larger, more top heavy?
It's a little bit longer lug to lug. I have 6.75 inch wrists and do wear an Emperor Tuna too (however weird that may look)![]()
Wow. Thanks so much for taking the time. Really appreciateYes the SLA025 is larger because it is taller by about 1.4mm and has a decidedly heavier watch head so it is bordering on a top heavy watch. Not that it is an issue, whereas the MM300 is not at all.
The lug to lug is nearly identical between these 2 watches and very wearable. I too have a 6.75 inch wrist so let these photos be a guide of some sort.
SLA025 on left, SBDX017 on right
HahahaI still fancy a SLA025 but would it get the SBDC001 off my wrist ?
Jon, can the end link be fitted a little better ?
Now that's cool. I haven't noticed!I actually use a spare MM300 ratcheting clasp on the Uncle Seiko Beads of Rice on my SLA025
