Aloha , does anyone know how to adjust the second second lever on a Seiko 6106-7510 25 Jewel watch ? The Lever stops the balance wheel when the crown is pulled to set the hands . Mine was working OK , but I dropped the watch while putting it on and now the watch stops periodically...It seems to be running alright as I write this though . I have searched the tech pages for the adjustment . but have only found reference to the lever but not anything on how to adjust it .
Any info is appreciated by me....fumble fingers :(
I don't think the dropping the watch would affect the hacking lever.It wouldn't stop the movement intermittently anyway.
It's either on or off. I would guess you have other issues that may have to be resolved with a service to the movement.
Thanks....it seems to be running OK now . I thought that the tolerance between the lever and balance wheel may be tight and could be adjusted with a tweak similar to the small corrections you can make on the Chronos . If anyone knows if there is such an adjustment I would appreciate the tech info for my tech/data files .
