Hi Gents,
I need help on the bezel for the Seiko Rally diver 6119-7173. I would like to purchase an original/correct replacement as much as possible and I was wondering if the bezel used on this rally diver similar with the one used on the 6105-811x divers? Does it also have a click ball? Because mine don't have the "clicking sound" when you rotate the bezel. The bezel just slides left or right but without any "click" unlike my 7002-700J diver. I just purchased this rally diver which is a none working one for my project and I am planning to bring it back to life using original replacement parts. Thank you in advance for the help!
PS: Will post photos of the actual watch as soon as I get a hold of a digital camera. ;)
Best,
Iver
Iver -
The bezel on that model does not have a click ball or ratchet. I do not know if the bezel is shared by any other models. Aftermarket bezel inserts are available.
Good luck!
The rally diver bezels are one of two types. One type uses a wire retaining ring and the other uses a rubber "O" ring. They are not interchangeable and match the case. The wire retaining style also uses a plastic ring underneath the bezel which fits in a groove in the case. The 6119-7173 most likely uses the rubber "O" ring style depending on the year. Neither style uses a click ball. They turn smoothly in both directions.
Oh its good to know that this model does not use a click ball. If thats the case I think mine does not need the bezel replaced yet. So the only problem that i have is fixing the movement and replacing the crystal. Anyway thank you so much! Appreciate the help guys! :)
o-ring or spring?
I have a SEIKO 5 Rally Sport 6119-8300 that has a completely separated bezel, and I'd like to know if its an o-ring or spring
Here is a closeup of the inside of the bezel:
and the outside of the case:
Any suggestions where I could get the relevant parts?
Regards, Jake
It's hard to tell from your photos which bezel you have.
The bezel that takes the "O" ring has a wide groove for the "O" ring close to the insert.
The bezel that uses the retaining ring has a narrow groove near the lower edge of the bezel and the case has a nylon washer for the bezel to rotate against that fits in a groove in the case just outside of the crystal retaining ring area.
Thank you for your feedback SeikoPsycho2,
From your description, I'm dealing with the retaining ring version.
Do you have such a ring for sale?
Or is this likely to fit? https://www.ebay.com/itm/Seiko-Watch-Bezel-Retaining-Spring/124086446114?hash=item1ce420e822:g:ODcAAOSwWcVeSdou
You're welcome!
There are several different Seiko retaining rings. I don't think the retaining ring in your link is the correct retaining ring for a Rally Diver. The Rally Divers use a ring with three outside curved tabs. I do have some available. PM me for details.
