Thank you. I had seen examples of this dial in my online browsings over the years, and liked the style of the bullet-shaped indices. It wasn't until recently that I was tipped off to the lume under the hands and in the ends of the indices that reflect off of the polished rehaut. That's when I started searching in earnest for a decent example. I decided to hold out for the low-key grey dial, as I've already got another, more ordinary Seikomatic-R with a silver dial.
When I did the lume, I chose the brighter formula for underneath the hands, as it would be less visible, and the slightly less bright formula for the indices, so that they don't overpower the hands. Your plan for BGW9 sounds cool too. I believe it's available in standard and 'grade A,' which is a bit brighter. When I charge mine up before bed, I can still read the time six or seven hours later, when my eyes are fully adapted to the dark.
I'm still developing my skills, so haven't attempted a much needed overhaul on this movement. I've got an earlier Seiko Slimdate that has a similar movement that I intend to use for practice first. It is a really nice movement, to be sure. Martin has a fantastic write up here if you haven't already seen it:
It is easy to develop a misapprehension, when first dipping one’s toe into the pool of what a particular watch company’s vintage back catalogue has to offer, that every watch is fitted with one or …
adventuresinamateurwatchfettling.com
If I ever decide to move it on, I'll try to track you down to give you first offer.
