Seiko Kinetic Sportura SKA511 - question
2838 Views 16 Replies 9 Participants Last post by  scubapro
Hi all, just got a used Seiko Kinetic Sportura SKA511.
As it didnt comes with the manual. Read some review on the net but none mention on the screw down "Power Reserve button".
The button did worked ! But i am wondering if the "Power Reserve button" screw down ? As it seems to be cosmetic only and i cannot seems to turn the screw thread at all.
1 - 17 of 17 Posts
on my Caesar, it is a real screw down crown, I can't see why it wouldnt be on this one.
Thanks..... will try again ; maybe with some plier and protection if it can turn ....
Tired, Ahhh....nope its not turning.
Should it lock clock wise or anti !!!!! just a thought.....:confused:.....Bob.
Is the main crown and stem screw down?
What's the depth rating?
I've seen but never owned plenty if dress screw downs but the seem to all be cosmetic unless rated 200m or more.
Main crown screw down OK.
Rated at 200m.
My guess its cosmetic too.
What are the 200 chronographs pressers like?
Its screw down 100%. I have 2 of these variants. Normal thread direction .
Thanks for the confirmation.
Think mine is jam !
I have had some of these where they have been very tight indeed. They can be undone without causing any marks if done carefully. Last resort use pliers but cover the jaws with tape /paper etc.
Failing that, i will take it off your hands :-
Seiko Landmaster kinetic has that button which is not screwed down and its rated to 200m.
I think the WR should be ok even if its not screwed down.
The BFK doesn't have a screw down power reserve button. Its 200m rated.
@jrpippen
Thats rigth.
The Caesar have a screw down button and the BFK haven't a screw down button.
From the original post it would appear that the thread is locked when it is down.
Like all these screw down buttons, the button does not depress when the collar is screwed in. The collar has to be loosened for the button to work.
So why would one need a screw down button and the other not, of both have the same WR?
Confirmed this ;)
1 - 17 of 17 Posts
