I picked up a Spork and like so many of my modern Seiko divers, the pip at 12 o'clock doesn't stop easily on the 12 o'clock position as it seems 'between' two clicks. So, I know how to remove a bezel, I popped it off and lo wan behold, one of the pieces that engages the bezel from that ring is broken off. so:
A - where can I buy a 'click ring' (name?) for a Spork?
When putting this back together to wear it until I can get said click ring, the gasket under the bezel insert (gross with wabi and dry as a bone - maybe part of the issue?) doesn't seem to be agreeing with me, and whenever I get the bezel back on the watch, it barely turns. If I remove the gasket it turns easily, but is very sloppy. So:
B - what's the trick on getting that gasket where it needs to be, but not catching on whatever I must be catching it on?
Thanks in advance.
Thanks in advance.
