1 - 13 of 13 Posts
Hello everyone
The mechanism was a little sticky so I decided to take the bezel off and give it a clean underneath
I think this is a different system to the SKX007/SKX009
Here I see a spring (which fits inside the cylinder with a flared end)
I was expecting to find a ball bearing on top of the cylinder but did not see one
Is my assumption correct?
Has anyone fixed this problem before?
Now it just keeps spinning around without the clicks, so need to apply a fix
469603
469601
469605
469602
The only spring cylinders I have seen apart from the Tunas was on 7002s, having the spring cylinder out of the case could be great because you could clean it, pean the end over so that the ball protrudes only ought to catch in the bezel, replace the spring and push the unit back into the case, job done and as good as new :)
Don't panic :) you just need a 1mm ball bearing because you have lost yours.
I just put my callipers across the end of the cylinder and that was exactly what I deduced my friend.
Found some on eBay.
Thanks for your help/support..(y)
Seiko Dive Watches, Rolex Submariner
Make sure you replace the bezel gasket too. I found that a new gasket helps tremendously in the bezel rotation function on that particular model.
Discussion Starter #8
I found only 1/4 of the bezel gasket in the watch but you're 100% correct with your statement - it does make a big difference.
Had to put a wire into the groove then use C = 2π r formula to calculate the diameter which came to 33.6mm
According to my research the bezel gasket is:
SEIKO 0G330BA11 - 0.7mm dia / OD - 34.40mm / ID – 33.00mm
So have sourced a generic one matching these measurements..(y)
You might reach out to John @TheTigerUK. If memory serves me, he has a connection/info on many different Seiko gaskets.
For some reason I assumed you had a gasket if I had known I would of dropped one in with your ball :(
John @TheTigerUK , correct me if I am wrong, but didn't you (or was it @GuyJ ) organize some gasket group buys a while back? Is it something you (or Guy) would consider doing again? I replace a lot of gaskets and buying them in small quantities (like on ebay) gets expensive and time consuming really quickly...
I did group buys for SKX and 6309 etc bezels, case backs and crown gasket, the prices worked out at a fraction of the cost compared to ebay/dealers prices but I don't think there is the same interest these days for the large quantities needed to make the project viable.
Generic are fine ;-)
1 - 13 of 13 Posts
