Greetings!
At long last, my slim 6309 was delivered last Thursday and I wanted to share some photos of the watch as received and after preliminary inspection.
I found this specimen in the Philippines in March, just as the global lockdown was enacted. All I had to tide away my time were photos generously sent to me by the seller; and boy was I excited! On first glance, it looked honest and original to itself, but there were a few problems. More on these later.
Here it is, freshly unpacked from its packaging-
I wasted no time in stripping it down for a complete cleanup and inspection.
The click ball is present and after an overnight soak in WD40, works as intended! I can't remove it from its crevice but I read that it's non-removable from the factory and only comes apart when worn out.
There's a small amount of corrosion and pitting here but it'll still be watertight.
Original crown with the elusive 'stem rest' intact. I removed the parts carefully and cleaned out the crown too-
Bezel and insert. Is this insert genuine? I'll probably replace it though.
Movement out
The dial is genuine and useable but needs a coat of matte varnish to hide some blemishes.
The movement runs but the rotor feels sticky when wound. I'm hoping a service will sort it out!
The hands are replacement I think. No matter, I'll paint these up like 7C43 hands and track down a set of authentic flat 6309 hands-
So here's the rundown-
The crystal retainer is cracked and will be replaced. The crystal is original but I've heard good things about Bry's 6309/7548 crystals so I'll be fitting one. Completing the whole project will be a set of VTA gaskets.
Stay tuned!
Jay
Movement out
Stay tuned!
Jay
