1 - 11 of 11 Posts
Hi John,
I wrote the lift angle so Paul can compare his mesurements with mine.
The older movements use mostly a higher lift angle, so I mesure the vintage Seikos on 52°. Couldn't find the exact angle it in the tech infos.
When you go on with 50° like on the ETA 7750, the mesured amlitude will drop arround 15°.
It's just a to have a scale when we talk about amplitudes :)
Best regrards
Uwe
Seiko's aren't known for its amplitude on the lower level calibres! Be happy with the daily rate and forget about amplitudes hahaha
Good luck!
Exactly. In fact, most of the technical guides I've seen don't mention an amplitude figure to shoot for. IIRC, my 6105B, which was overhauled by IWW for the previous owner, shows around 250-260° at full wind (lift angle of 54.5°).
I think the lowish amplitudes seen in the low-end Seiko calibres is due to the deep locking. Less-than-exact locking depth probably makes for easier automated assembly.
Myles
1 - 11 of 11 Posts
