1 - 7 of 7 Posts
Hi,
Just picked up a Seiko 4205-015K (SN:120135) . Its had some unhappy refinishing attempts and the bezel is loose,both horizontally and vertically, any idea how to fix this? A new gasket perhaps? I cant seem to find one!
Thanks,
(UK based) Leon
Hi Leon
Nice to see you over here - welcome to the Forum.
I've just had a look at one of my 4205's, and there doesn't appear to be a bezel gasket. The bezel is nice and tight on mine, so I can only assume that they never had a gasket.
Perhaps the "slack" is due to wear, or the refinishing the watch has had.
This may come in handy http://www.watchuseek.com/seikocitizen/SeikoTechnicalManuals/4205A.pdf
Hi,
Thanks for the warm welcome and advice, I have an update. Prized the bezel off and I have a gasket :
http://smg.photobucket.com/albums/v218/dubleon/?action=view&current=bezel.jpg
It sits in a groove the bezel, it does not fit tight in the groove as it does not seem wide enough. Would anyone know if this is correct? I hope I have explained things well.
Here is where the bezel fits:
http://smg.photobucket.com/albums/v218/dubleon/?action=view&current=seiko.jpg
almost looks like glue in there- old grease maybe?!
There is also a crack you can see here:
http://img.photobucket.com/albums/v218/dubleon/seiko2.jpg
I think the easiest thing would be to buy a repalcement case from ebay and swap everything over?
Leon
Looks like the crystal retaining ring is broken - there's what appears to be a crack in it, in pic 1. If the ring is loose, maybe that's why the bezel wobbles?
I've taken a few 6309s apart, and the 4205 looks to go together in a similar way. A couple of them have had cracked retaining rings or worn bezel O-rings, causing the bezel to wobble. Parts are readily available from eBay sellers in the Philippines for the 6309. Not sure about the 4205.
Thanks Clockworks,
The movement is having some problems so I am sending it back to the seller who has agreed a refund! Expect me to pick up another Seiko soon!
Leon
Probably the best thing to do, Leon. Go for a 6309 (plenty of aftermarket parts) or a 7S26 (007, 009, etc. - newer, so movement should be OK). If you want a slightly smaller watch, the "submariner" is a good choice (SKX033, with 7S36 movement).
1 - 7 of 7 Posts
