1 - 20 of 21 Posts
Last week i received a sapphire from Rob (robbie409) that was custom made for my Seiko H601-5481. Rob arranged it for me, he has a friend who makes these. Rob wanted one for his H601 and his friend made one extra for me. I also exchanged the bezel insert with a new one from Noah. Here is the stunning result:
The sapphire I send to Yamaha was intended for the H558-5000 Anrie :)
Got it from Yobokies.
Crystal H601: 310P13HN02
Crystal H558: 310W60GA00
http://members.chello.nl/r.herpt/Pics/Crystal_1.JPG
http://members.chello.nl/r.herpt/Pics/Crystal_2.JPG
http://members.chello.nl/r.herpt/Pics/Crystal_3.JPG
http://members.chello.nl/r.herpt/Pics/Crystal_4.JPG
H558: crystal is placed on the fat gasket and pressed down with a crystal retainer ring.
H601: crystal is pressed in the nylon gasket...
Good to know that the H558 sapphire has survived the pressing in the H601 case.
Discussion Starter · #9 ·
Fits like a glove :)
mine says hello:
Sapphire fitted.
To do:
put my NOS bezel on it, now I made this picture I see the scratches on the bezel
replace the dial plate, it broke when it was ouside the watch (see below the 6-index). Lucky I did not sell the NOS one I have :)
replace the hands, I have a set of H558 hands, they will do.
beautiful watches..has anyone done a complete overhaul?...would love to find info about this...
hey how hard is it to remove the old crystal?..does it need to be pressed out?...i worry about damaging the bezel insert...
H558 and H601 are the same crystal so fit into both watches no problems
the chamfered edge on the H601 is a gnat dick more than the H558 and that's the only difference
Crystals press out with your fingers like most other dive watches - you need to pop off the retaining ring first though
so there is no retaining ring on the H601?..that is what i thought too...it must need to be pressed out too?...thank you for clarifying
i need a h601 dial plate..mine is broke in the center..i may be able to repair it..but would love to find full set of gaskets and i need a crown as mine is missing....
Discussion Starter · #18 ·
Yes crystal needs to be pressed out. Crown is a problem, also the thread on the H601 case is often worn out or damaged. I had 2 H601 cases with that problem but got it fixed with a trick...
well everything else is in great condition...threads on back and crown threads screw in tight.....i need that inner bezel as mine is split...i am told that it can be repaired...and i need a full gasket set too..any help will be greatly appreciated....John
1 - 20 of 21 Posts
