hello,
Can you tell me if i can take off this little parts 'little channel" inside the seiko case ?? is screwed or afted strenght ??
thank you very much for your answer.
best regards
philippe from Paris
If you could explain why you need to remove the part, someone may be able to suggest a way to fix the problem
I believe that the 6105 tubes are not designed to be removed. Randall Benson can replace them, but it is very delicate and skillfull work. I think the old tube has to be drilled out, and then a new thread is cut into the case, and then a non Seiko tube is screwed into the case.
A forum community dedicated to Watch owners and enthusiasts. Come join the discussion about brands, troubleshooting, repairs, reviews, accessories, classifieds, and more!
