Has anyone used the mineral "hardlex" crystal for their 6309 diver from ebay seller paulynn_collections? According to the seller, it has the frosted bevel edge. I'm concerned about the fit and quality. How about the crystal ring and crystal gasket offered by the same seller?
I've fitted a crystal, 2 gaskets and 2 retaining rings from that seller in the past few weeks.
The gaskets need to be stretched very slightly before fitting. Easy to do, and ensures a perfect fit.
The crystal was fine.
The retaining rings needed a little work. They fit the case with no problems, but the inside edge (where the crystal comes through) needs opening up slightly. Takes a few minutes with medium grade wet-or-dry sandpaper. I guess they make them slightly small so that they can be adjusted to suit individual crystals or slightly compressed original gaskets.
Next time I need these parts, I'll be buying them from the same seller.
