An old friend of mine asked me to take a look at an Omega Chronostop with an 865 movement as the minute hand had become loose (see picture).
He had inherited it from his father who back in the 60s was Queen’s physician for a while so maybe he used the Chronostop mechanism to take the Queen’s pulse.
I am reasonably competent at stripping down Seiko movements so I said I would have a look. Removing the movement from the case was fairly straightforward once I had discovered the little screw (circled at 8 o’clock in the second picture) which is unscrewed to release the crown. Removing the hands and then replacing them correctly was also not a problem. However, while handling the movement the crown release screw fell out and now will not catch on its threads. So is there something I should be doing to allow me to re-insert this crown release screw?
Thanks
Chris
Thanks
Chris
