1 - 11 of 11 Posts
Ideally, I would like:
* barometer / altimeter
* thermometer
* radio-controlled
* solar
And ideally, a street price under $175. If it has a compass that's fine, but doesn't bother me either way .
Is the G-Shock GW9200-1 Riseman the right model? Anyone here have one and like or dislike it?
Thanks VERY much in advance!
Chris
I have a Riseman and have had a couple of Pro-treks.
Riseman doesn't have the compass.
Size is the issue- I doubt youll ever get a Pro-trek under a work shirt, but you might just about with a Riseman.
I think out if the 2 watches though the Pro-Trek is easier to read and is pretty cool.
You can get a used one for very little money if you keep your eye out for one
Regards
Jem
Re thermometers on watches: as long as the watch the watch is on your wrist, you don't get a good read on environmental temperature - your body heat dominates. I suppose this might change if you wore the watch outside your shell layer.
I suspect - but I'm not sure - that even then the sensor wouldn't take into account wind chill and humidity. Which would make it useless in the conditions I'm used to in the UK - you can be much colder here above zero than below.
true, but the temperature doesn't change.
The perception of how cold you are does.
I'd disagree with these use of the word "perception": you don't just think that you are colder if the wind is higher and humidity greater at 2C - you ARE colder. (Because you are losing heat faster.) Once you realize this, a thermometer on a watch isn't that attractive - imo.
The thermometer isn't accurate on your wrist when it's cold, but you can take it off and let it equalise (say, strapped to your pack).
It's a cool gadget in the Aussie summer - I'm proud to have endured 45 degrees celsius! :mad:
(glad to see you finally made it here Jonathan!)
1 - 11 of 11 Posts
