I need to know the comparison of Aqualand C023, 022, 021,
.... " Movement Stems ".
What other stem's will fit these watchs ?
Thank you very much
Aloha LongBike / Louis
well that is a great question...you are just talking the removable stem....it does look familiar ..i will try and find out
Sometimes it helps to know what won't work. This one is from a 5862-F80103 Aqualand Analog (small version/womens). You can cross it off the list. Wish I could be of more help. Maybe the duplex series are close?
Long Bike...i just installed a Ronda 515 and that stem looks very close...
Thanks guy's , guess I have to keep looking for comparisons.
There has to be a few out there that match.
Just the ...." Stem " be fine the rest I can do.
The main part is fitting the ..." O-ring ".
That is the .." Case Seal O-ring Gasket " on the stem.
There is another inside the Crown also, and I have those also.
I have O-ring Kits here I use if needed.
I have those I compared with other ...." O-rings " , I have here.
Aloha Louis / LongBike
Shovel ,
I tried the Duplex it is a little different too.
Also the Echo Drive ones and the same thing.
______________________________________________
I have a C506 Duplex that still needs the .....
" Sweep " hand gear yet. ( I think that's what its called ?? )
That thing is hard to find yet. I tried the Aqualand C Series one to compare it but it is a (No Go) also.
Aloha Louis
