Please excuse my ignorance if this is a stupid/obvious question.
Would it be a straight swap from a Seiko 5 into an SKX case and vice verse (obviously changing the crowns over)? Both have 7S26 movements with 4 o'clock crowns.
I'm wondering what an SNXS79 dial and hands would look like in the bigger SKX case with a polished chapter ring.
Thanks in advance.
I think this will work. Although if I'm not mistaken SKX uses a slightly thicker dial/movement holding ring. If movement rattles in case then you will need to swap out. Crown will work. This will be a good mod. Good luck
