Looking through my odds & ends today I came across this movement ring but can't think what it came from.
It will be Seiko as I have broken one or two for the bits but not other models.
It would be nice if it turned out to be the 7C43-7000 I need but things don't usually work out like that. :undecided:
It is 2.25 mm tall and the outer circumference is stepped with the step at the dial side being .5mm. It is 29.1mm across as is a 6309 one.
It has 3 square "pips" around the upper side. The movement side is completely flat bar the stem notch. There are also 3 separate cut outs around the side wall which you can just make out in the photos, these might be a clue to someone. TIA
