Looking for all replacement gaskets for Aqualand C023
6.4K views 24 replies 11 participants last post by  jringo8769
#1 ·
Hi All,
I have been trawling various sites for the past few months looking for all the gaskets for an Aqualand C023 (my pride and joy for over 20 years) - but have only managed to find a new caseback gasket.
Here's the issue: under a pressure test, at about 5ATM, a bubble under the crystal starts to appear. I have had the watch since new and my suspicion is that one of the gaskets needs replacing, and since I still go freediving with it :unsure:, I effectively need to replace all the gaskets, ASAP!
Would anyone be able to help me find the other C023 gaskets, i.e. push-button gaskets, crystal gasket, etc?
I have already tried the following sites/companies but to no avail:
GOLDTIME BL, Slovakia
speedtimerkollektion.com
swissforniture.it
stsupplyonline.com
(and waiting to hear from CousinsUK)
Any help would be hugely appreciated, thank you!
#6 · (Edited)
Have you ever dived at 50m? I certainly didn't, but if you try, your perspective will change about what is "only".
In recreational diving, a depth below about 30 metres (98 ft), where nitrogen narcosis becomes a significant hazard for some divers, may be considered a "deep dive".
https://en.wikipedia.org/wiki/Deep_diving
Of course there is people like the OP here that nonchalantly does deep free diving in shark-infested waters, best of luck to him then :)
#4 ·
I regularly freedive to 20-30 metres, and of course the pressure test is only static and approximate.
So if I'm at 30 metres (3ATM) and start flailing my arms (e.g. because I see/fight a shark) then I'll no doubt exceed the static test pressure of approx 5ATM.
I know, a dodgy gasket will be the least of my issues under those circumstances but I really don't want my beloved Aqualand to die!
#9 ·
#11 ·
Thanks for all the advice.
I agree that manufacturers 'underestimate' when stating a static ATM pressure. My 5ATM test, however, is just that, an actual reading, so I know there is an issue long before my C023's stated depth rating of 200 metres. Even though dynamic pressures may not be that much more than static pressures, at a depth of 30 metres I am just too close for comfort to the static test pressure of *approx* 5ATM. I could of course just not wear the watch when I go diving but it is a dive watch after all! There is also something very satisfying about having a 20 year-old Aqualand keeping track of my freedives.
As for diving depths, which I am sure could be a forum topic on its own, diving below 98ft is perfectly safe, albeit you can not stay at those depths for very long using a standard air mixture. When freediving nitrogen narcosis never becomes an issue - at any depth.
Back on point (apologies), I forgot to add Hurley Roberts to my original list. I have also tried the American chap on the bay that I have seen mentioned in other posts (sdcarbal.watch.repair). Both of them have also been unable to help. They have suggested "aftermarket gaskets" - LongBike?
#21 · (Edited)
Aloha ,
( Yes that was me that said that.... I have never used them at all. )
Most not to be used at all ..... " Disregard all A/M ", for these, not worth the destruction if you love them. Pressure is a very strange thing when diving
but if you want them to still be loved don't use them to dive.
I can say a little of it and can maybe prove a little with what I have collected.
( JMHO )
Louis / LongBike
#13 ·
Thanks 7s26b
Using this website I can see a number of part numbers for the C023-088069: boley.de/en/case-parts/citizen/8821?search=4-088069
(I can't create a proper link as I have not yet made enough posts)
That website includes the "Bottom Gasket" (caseback I assume) and "Bezel Gasket", both of which I will order.
What other gaskets are there on this watch? Push-button? Depth sensor? Crown? Crystal?
#18 ·
Hi There -
New to the forum - but I just had one of these watches rebuilt (needed a new stepper motor after running since 1989) - the watchmaker can not get it to pass a seal test, he says it needs a new case back gasket - anyone know where I may be able to find one?
I tried ST Supply - but they said they are out of the gaskets and can't get them anymore
Thanks in advance,
Josh
#19 ·
Crystal gasket is actually a nylon L shaped gasket and basically the crystal is pressed into place to make the seal.
I used to have loads of the caseback gaskets.
I may still have some in my inventory.
And yes they are like the proverbial hens teeth to get hold of.
Silicone greasing the originals can still work if the gasket is not badly compressed.
Plus The COx series Aqualand with its unusual caseback shape and 6 screws design was never really the best design for a trustworthy seal? And I have 46 of them!
Hence why the reissue Aqualand caseback became a standard screwdown design.
#20 · (Edited)
Agree' on these points.
Myself I have a few of them and I make my gaskets ( O-rings ) with a Mechanic's O-ring kit. I make my seals like I would make any seals
for when I worked in my field of work and still do.
I am a Fuel Injection and Re-builder of Many types of fuel Pumps also in line with Diesel and Mulit-Fuel Pumps, also Drag Racing parts when needed.
These watch's I use also and have dived with a few of them but I make extremely sure that those I have dived with were very much restored.
I would never use any of my Aqualands especially my C- Series and other like it and damage them with water leakages.
I cherish them to much to use them extensively. But they all are very water tight also.
I have struggled to much in collecting them so they don't get diving times.... " I prohibit them for diving use and I never ask any of them
if they want to go diving or even get wet .....hahahaha ".
It took a while when I first stared to collect my watch's, but once I did it then I used a couple of them.
I did not have any thing to use when I first started so by experiences in my line of work I developed my own and they work good too.
I strongly agree with ... Neilo and Scubarob99 and the shovel ... on their expressive points on ..." Case back / Crown Design ", and would only use a watch with a
screw down crown and a screw case back and on what is mentioned. Now if it was designed with a ... " Crystal locking Ring ", it would help a lot also.
The importance of those ... Nylon Crystal Gasket's is a very important part of these watch's. They are beautiful but one mistake and it will destroy
your cherished watch and damage them. I never have any watch I have with water.
A good and worthy ... " Computer / Diving watch " , will serve you much better for diving purposes.
When some one asks me .... " Do you dive with those Aqualand Watch's " , the hair on the back of my neck stands up and I say .... NO, NO,
" They are my cheris-ables " no way .....hahahaha.
Aloha
#24 · (Edited)
Aloha ,
They probably can be found yet but one has to really research to find them I would say. You can make them like I do for my own. I use a ....
" Mechanic's O-ring maker kit " . I also am a Fuel Injection Pump Certified Repair Guy so I have Kits for doing these things for mine.
I made a set up to hold and assemble ....The O-Ring material when making what I need and it works for me. All you have to do is fine the right size
( OD - , the right measured length and the right recommended Glue that is used for making these and know how to cut them properly.
Since it works for .... ( High Pressure Pumps ) , it has to work for this simple applications. I even have used it in the Ocean for a few watch's I have
If you take your older but still usable gaskets to a .....( Fuel Injection Repair Guy ), he can match a lot of them for you and their size in thickness
but then you will have to ....( Measure length, Cut to length and then do the rest. )
Here is a little trick to do:
The O-ring material will be measured and made but it wont have the correct shape like for the original case back so you place it into some boiling water,
but not to long ....OK ?
_____________________________________________________
First :
But first make a Jig the shape of the original gasket.
Make it with some small wood dowel pegs or use some of those ....Tooth Pick and stick them onto a piece of board it will work good.
( Maybe drill the hole for the Pegs/ Tooth Picks and press them into the wood. ( I made a Plastic one for my uses.)
Now when it becomes just a little .... Hot it will soften ... then quickly place it on the Jig and let it cool and it will become the shape of the .... (Old One )
and then can be used.
( Remember it has to retain the correct ...Diameter Size when it cools then for use. )
NOTE: ( Do not over stretch the new one ) .... just enough to be the size of the old and it will work great.
Louis
#25 ·
hey why has no one contacted Adrian and have him make the CO23 gaskets?...he makes them for everything else?...
