1 - 10 of 10 Posts
Difficult to say from the low resolution pics.
Dial looks good, hands im not sure about, id need better pics.
Bezel insert is AM.
It has the later type movement so should be from about 1991 onwards
The watch should be a 7002 7001, what does the case back say?
Look on Fleabay theres lots of horrible 7002's with coloured dials and fishbone hands that fetch more than $120.
If you like it, go for it. Just be aware that it may not be completely original.
As to what its worth, is it running OK? is the case back correct to the dial?
I would pay £120 for it, but then i have the spares and the ability to sort out any problems, if you have to pay someone to sort any problems then you would be better off finding a good clean one for $100 or so more.
Banned
Yes it is running and has the 7002 case back. He says the bezel is a after market.
Think I'll pull the trigger . Had one before and regret selling
Banned
Discussion Starter #8
Its the 4 digit number after the 7002 on the case back thats important.
The dial is from a 7002-7001 or 700J, if the case back says 7002-7000 for example you know its a franken.
Trying to make it out
I believe it's correct he says it's a j
It does look like a 700J so its correct to the dial.
The 700J is a JDM version and should have a pepsi bezel insert.
Yobokies do a very good copy of the original insert.
Id buy it but, then im a 7002 anorack:grin:
I had to look that up as I had never heard the term used for other than a long jacket with a hood :cool:
1 - 10 of 10 Posts
