I have a 6105-8000, Im planning to change the bezel insert, I have a lot of spare bezel inserts from different divers, skx, 63's, 7002... However non of them seem to fit the 6105... it seems the spares I have are a bit bigger for the 6105... Are they supposedly the same? or 61's bezel insert outside diameter is smaller? What should I do?
Thanks,
Enyong
The insert diameter of the 6105-811x is around 38.1mm the 6105-800x has a smaller insert diameter of approx 37.1mm.. you could sand down the larger inserts to fit, just be aware that the smaller 6105-800x inserts also had a different finish to the larger more textured inserts of the 6105-811x and 630x's.. good luck Clayton
A NOS 6105-8110 insert..
