Doddle yes, but that coil is fragile. Treat it gently.BTW: these movements are a doddle to work on in the scheme of quartz.
OOOO, nice. Please get this working. Its a very nice subtle MOD. I like it a LOT :clap:
What he said.....:wee_hee:.....Bob.You do not need to fit the sweephand necessarily to see if the movement is working. If you look at the gears behind the gear train bridge with a loupe you can just about see the stepper motor/rotor, it will flick every second, you may be able to see other gears moving too, albeit slowly.
Fair point Mike and same to the man that said to fit the stem- I hadn't spotted that.You do not need to fit the sweephand necessarily to see if the movement is working. If you look at the gears behind the gear train bridge with a loupe you can just about see the stepper motor/rotor, it will flick every second, you may be able to see other gears moving too, albeit slowly.
Ok thanks Merritt - I'll try tomorrowGive the second hand a helpful push, carefully with a toothpick and this will get a twitcher going!
