WITHDRAWN Selling a Seiko Large Cushion Case 6105-8119 150m Divers Watch with All original parts (except new crystal and bracelet) and serviced by International Watch Works (IWW). While at IWW the watch had a New crystal installed, Original Dial and Original Hands were relumed, movement serviced, all new gaskets installed, and watch was successfully pressure tested. Please note that Jack does beautiful work but is often extremely backlogged so getting a watch restored takes a long time - sometimes a VERY long time. Always well worth the wait but here is a beautifully restored watch available right NOW! A beautiful example of a Classic Dive watch that is ready for regular wear. Price is $1150 - Reduced to $1000 shipped CONUS Paypaled. International shipping available at $50 additional. Sorry No trades. PM or for faster response please email bigbluekyle(remove)@hotmail.com
HERE ARE THE SPECIFICATIONS:
DIAL and HANDS: Original dial and hands in Very Good condition. Dial is crisp and clear. Original hands and rectangular lume wells in great shape with no oxidation or discoloration. Original Dial and Original Hands were relumed at IWW using Seiko superluminova. Perfect application and maintains a correct vintage look. Watch now glows like a torch all night long. Pip dot on the Bezel Insert was also relumed and matches the dial perfectly.
CRYSTAL: Crystal has been professionally replaced with one of Jonathan's (Swedefreak) reproduction crystals - a 1:1 exact copy of the original. Crystal is Flawless with no scratches or blemishes.
BEZEL and BEZEL INSERT: Original Bezel and Original Bezel Insert in Very Good condition showing only light wear from use. Bezel is Bi-directional (turns in both directions) and operates smoothly with no play or looseness. Bezel insert is original with the original deep gloss black smooth finish.
CROWN : Original Seiko Crown with Lock and Arrow working perfectly. Unique Non-Screwdown twist and turn action works as it should with 1/2 turn/twist to lock the crown in place.
CASE and CASEBACK: Original case and caseback showing light wear and scratches from normal use. There are small dings and nicks to the case edges and some scratches around the crown guard. Case has not been refinished and retains its original correct factory brushings with the original crisp and sharp case lines. I prefer to leave my vintage watch cases alone and not have them refinished as any normal wear marks from the previous owner are part of the history of the watch. Caseback markings are crisp and clear and has a serial number 6N1134 and was manufactured in November 1976.
MOVEMENT: Original Seiko 6105B Japan Automatic movement with Hacking is running strong and keeping excellent time. Movement was cleaned and serviced at IWW including timing and regulation. All gaskets were replaced including crown gasket, watch was successfully pressure tested, and ready for water or diving.
BRACELET: Comes with a High Quality Signed Seiko Super Oyster Stainless Steel 22mm Wide tapering to 20mm at the clasp Bracelet with Custom fitted Solid End Links designed specially for this watch. Very high quality bracelet with solid link construction, screw in pins, and Signed Seiko Fold Over Clasp. Bracelet is currently sized for a 7" inch wrist and includes 1 extra/removed links and can fit up to a 7 1/2" inch wrist. Bracelet is in excellent condition with very little signs of wear.
BOX : Comes with a Seiko Deep Sea Blue box.
