1 - 11 of 11 Posts
I thought I'll make a separate thread for this.
I recently got a whole bunch of different Seiko parts in. Many I can't use myself, so I thought maybe some of you would be interested in any of these.
Genuine NOS Various Seiko Parts - Never used or sized. For all kind of different Seiko watches.
Price starting from $5 USD up to $15 + $8 worldwide international shipping. Price is per Seiko part. Postage is the same, no matter the amount purchased.
Please PM me if you need any more information. Please also see my other threads for more Seiko parts or watches
List of Seiko Parts available:
012802 Setting Lever Screw 15a
013112 Tube for Bridge Screw short 1104A, 44a, 15A
013953
014217 Diashock Spring Bellmatic 4006A, 6215, 6218, 4520A, 603, 4420A, 7025A
014317 Diashock Spring 6105B, 1104A, 6106, 5106, 5206, 6138A, 6139A, 5606A, 6119C, 61A
015113 Diafix Spring 394 Seikomatic Selfdater, 6206A, 6205B, 6159A, 6119C, 66A
022458 Oscillating weight screw 6139, 6138, 6105A, 6205B, 5626A, 5625A
022490 Screw for Oscillating Weight 2706A, 5M42
022677 Date Driving Wheel Screw 6109A, 6139B, 6106A, 6106B, 6118A, 6109A
022760 Date dial guard Screw 6102A, 6105B, 6117a, 6139B, 6138B, 6159A, 6119A, 6119C
027492 Pin for plus terminal of battery connection 78A
205101
• 224111 Hour Wheel and Cannon Pinion
11A
231112 Third Wheel & Pinion 11A
238001 Stem Pipe V232A
238231 Stem Guide Pipe V230B
241805 Fourth Wheel Sweep Second Wheel & Pinion 4006A Bellmatic
261110 Minute Wheel 1104A
261121 Minute Wheel 1220, 2G28
261865 Wheel Minutes Y147A
270024 Center Wheel 7122
271577 Hour Wheel Y573A
271776 Hour Wheel 5Y00, 5Y01, 6530, 6531, 8121-6000, 8121-8000
281110 Setting Wheel 1104A, 11A
281210 Setting Wheel 21A, 21D, 2118A, 2104B
282017 Clutch wheel 7123A, 7430a
282100
282122 Clutch 2C20
282140 Clutch Wheel Y432B
282150 Clutch Wheel 1520B
282210 Clutch Wheel Caliber 21D, 2118A
282250 Clutch wheel 2517A, 2517B
282849 Winding Clutch 8306A
283100 Winding Pinion 10C, 1520A
283150 Winding Pinion 15A, 1520A, 1520B
283210 Winding Pinion 2100D, 2104B, 2118A, 2119B, 2140A, 2160A
283250 Winding Pinion 2517B, 2501B, 2505A
354655 Stem H556, H557, 4006-6020, 4006-6029
373250 Winding Stem 11A, 1104A 17A 2202A 2205A 2206A 2220A 2406A, 2245A, 2501A, 2505, 2517B, 2623, 2625b, 2626b
381004 Click 7005A, 7006A, 7025A, 7009A, 7S26
381008 3020A
381560 Click 5606A, 5641A, 5601A, 5605A, 5625A, 5626A
381581 Click 2706A
382110 Click Spring 11A, 1104A, 2202A
• 382120 Spring
• 382660 Click Spring
66B
383110 Set Lever Push 9310, 11A, 10C, 1104A
383140 Set Lever 14B
383150 Set Bridge 11A, 1520B
383213 Setting Lever 2620
383419 Setting Lever 6619
383611 Click Lever with axle 6106B, 6106C, 6139B, 6119B, 6119C
383755 Setting Lever 8123A
383943 Setting Lever 6602B, 66B
384017 Clutch Levers 7123A
384110 Yoke (Clutch Lever) 1104A
384210 Yoke (Clutch Lever) 21D
384260 Clutch Lever 2626B
384660 Yoke (Clutch Lever) 66A, 6618A
384943 Yoke (Clutch Lever) 6619a, 66A, 66B
385110 Yoke (Clutch Lever) 1104A, 11A
385150 Clutch Lever Spring 21D
• 385152 Clutch Lever spring
• 385152 Set Spring
386100 Setting lever spring 1004B, 10A
386110 Set Bridge 11A
386170 Setting Bridge 17A
• 386210
• 386211 Setting Lever Spring (Setting Bridge)
21D, 2104b
388150 Setting Lever Spring 1520B
388821 Setting Lever Spring 8223A, 8222A
390100 Set Lever Axle 47A
390210 Setting Lever Axle 21D
390770 Setting Lever Axles 47A
397003 Lever for unlocking stem 7006A, 7009A, 7019A, 7025A
397610 Second Setting Lever 6105b, 61A, 6106B, 6119C, 6159
401113 Mainspring 11A
401150 Mainspring 1520B, 15A
401660 Mainspring 6602B, 66B
491260 Dial Washer 7223A
553220 Auto Click Spring 2205A
556350 Date Finder 8C22A, 8C23A, 2A23, 2A27
632250 Date Corrector Finder 2517
632610 Date Corrctor Finger 6106A, 6106B, 6119
687250 Date Connector Finder Spring 2517A, 2517B
701725 Fifth Wheel & Pinion 7A28, 7A38
719260 Day Corrector Y433A
• 719576 Day Corrector
• 735231 Winding Stem Holder
2B21A, v230b
735480 Stem Holder Y480A, Y481
802755 Day Date Drive Wheel with Finger 8123A
803601 Setting Wheel Lever 6309A, 6306, 7546, 7545, 6319, 6308
808155 Date Dial Guard 5123, 6533a, 6532A
808260 Date Dial Guard 2623, 2624, 2626
808820 Date Dial Guard 8229A
808865 Date Dial Guard Y14
• 810011 Date Jumper
• 810619 Date Jumper
6102A, 6105B, 6106B, 6117A, 6119B
810720 Date Jumper 6619A, 4006A, 8306A, 5717,
811001 Date Spring 5139A, 5126A, 5106A
811220 Date Jumper
• 811720 Date Jumper Spring
4006, 6215, 6217, 6205B, 6602A, 6619A, 8305, 8306 394 Seikomatic Selfdater
817260 Intermediate Date Wheel 2626B
823619 Electric Post 6105A, 6105B, 6109A, 6138A, 6106B, 6119C
867900 Date Drive Wheel 0903A, 0922A, 0923A
875002 Day Jumper 5126A, 5139A
880610 Date Corrector 6106A, 6119
884283 Holding Ring / Dial Ring 7009-5000, 7009, 7019-5130
884581 Holding Ring for Dial 2706A
884639
• 936610 Day Clamps
4146781 Stop Rotor 7813A
4216160 Cell Insulator 16A
4225480 Holding Spring for battery Y480A
4225650 Holding Spring Battery H357A
4242075 Terminal Battery Connection A259A, A239A, A258A
4242780 Plus Terminal 7810, 7812, 7813, 9923, 9942
4242941 Terminal Battery Connection M354A, M159A, M158A, M154A
4246021 Buzzer Lead Terminal H461A
4264900 Battery Connection (+)
4270020 Neg. Cell Strap 4312A, 4303A
4270140 Power Contact 14A
• 4271130 Battery Connection (+) 1320A
• 4271717 Cell Connector
• 4282941 Contact Point Lever
M158
80600363 Case Button
• 80611741 Push Button Yellow
M354-5010, M354-5019
81180210 Plastic Collar / Dust Pipe 1100, 1104, 1520, 2202
81180250 Dust Pipes
81181030 Crown Pipes
81182699 Bracelet Fixing Pipe http://cgi.julesborel.com/cgi-bin/matcgi2?ref=\][MYJ%5CN
81350180 Bezel Clicker 5G23, 5H23, 5M23, 5Y23, 6105, 6309, 7548, 7549-7010, 7A28, 7A38, 7T43, 8123, 8229, H558-500A
81400623 Botton Lock Washer
82701680 Movement Ring 6430-5229
83100981 Movement Ring 7005, 7006, 7009, 7019, 7025
83118150 Case Ring http://cgi.julesborel.com/cgi-bin/matcgi2?ref=\_[F_EXE
89997392 Button Lock Springs A127, A128, A129-500, A134-5000, A134-5009, A156, A158, A159-5009, A159-5019, A169, M154, M158-5009, M159, M354, M929-5020
Discussion Starter #2
SOLD:
1X 83100981 Movement Ring
2X 397610 Second Setting Lever
1X 810619 Date Jumper
1X 383419 Setting Lever
SOLD:
1X 03E02AN hand
1x 022458 Oscillating Weight Screw
1x Wyler Crown
1x 998613/999613
1x 241805 Bellmatic Fourth Wheel
SOLD:
3X 999613 Indicator Wheel Spring
1X 868611 Day Finger
1X 388821 Setting Lever
1X 401660 Mainspring
SOLD:
2X 999613 Indicator Wheel Spring
1X 998613 Indicator Wheel
1X 357612 Stem
2X 310-003 Balance
1X 500471 Oscillating Weight
SOLD:
2X 0B2810B01 Gasket
1X 4242941 Terminal Battery
1X 388820 Setting Lever Spring
1X 4001951 Circuit Block
1X 0C3060B01 Gasket
1X 251012 Escape Wheel and Pinion
1X 632610 Date Connector
2X FH3080B0A Gasket
1X 811720 Date Jumper Spring
1X 880610 Date Corrector
Discussion Starter #8
SOLD:
2X 553220
2X 401113 Mainsprings
2X 0J2820N01 Gaskets
1X 0E2930B04 Gasket
1X 015113 Diafix
1X DC2820B Gasket
Discussion Starter #9
SOLD:
1X 0B2910B04 Gasket
1X 351580 Stem
1X 401441 Mainspring
1X 884931 Dail Holding Ring
1x 80611741 Push Button
1 - 11 of 11 Posts
