1 - 20 of 29 Posts
So here's something unusual.
I have a 7548-700A. This model has a grey painted edge to the lume on the dial and the lume itself has always had a greyish tinge.
I serviced it and replaced the crown and caseback gaskets a few weeks ago and had it 50m pressure tested so I could take it on a beach holiday this summer.
Well it took its first brief swim in the ocean yesterday and it got a lot of heat and sunlight today and I noticed that the lume was now a solid grey. There has been no fogging up, so I don't believe that any moisture has got inside.
Has anyone else ever experienced such a thing? The hands are off a different watch and haven't reacted in the same way (except perhaps the tail of the second hand).
Before:
Now:
Interesting, looks to be moisture, you should contact lume powder experts.
Was the L seal and crown seal replaced?
Just the crown and caseback gaskets, Bry. Actually, they are some of your gaskets. I didn’t do the crystal gasket, but perhaps I should have. The pressure test reassured me that it was good.
I’m guessing that the paint behind the lume is grey, so perhaps moisture has made the lume translucent?
I knew I should have bought a case opener with me.
No chance of opening it up anytime soon, unfortunately.
Now that I think of it, it had about an hour in a swimming pool last week without any issues.
I've worn my 7548-700C swimming to the beach and the indices didn't turn dark/grey like yours.
It's just a small sample size though as I only wore it once.
Sent from my SM-N935F using Tapatalk
Contact adhesive and a wooden lever should work sufficient.
My crown and caseback seal should pass 15bar no worries.
I've had a similar experience with a 6309. Didn't go swimming with it, so no moisture ingress, no fogging. Leaving it on a sunny window sill on a 90°F day, darkened the lume to a gray shade
Rob
Sent from my SM-G930V using Tapatalk
My Pulsar Y112's lume has the same gray color, was already gray when I got it so no idea what caused the shift.
Sent from my SM-N960U using Tapatalk
I have seen this over and over...Over the years LOL ! Anyway I believe it has to do with heat via sunshine. I have several in my collection with this natural occurrence. For your viewing pleasure...
Discussion Starter #13
Now that I think of it, I had a 7548 years ago with ugly grey lume. I moved it on.
This 'cooking' must have occurred very quickly. I don't remember noticing anything when I put it on in the morning. We went to the beach at around 10 and I have a wrist shot around 11 when the lume is already noticeably grey. The UV would have been high. I was out in the direct sun for another hour or so (properly hatted and sun-screened up). I have another wrist shot around 4 where it's darker again.
Here is a thought. I would have sun-screened my arm twice during the day. An hour before the 11am shot and an hour before the 4pm shot. Sweat plus sunscreen chemicals form a vapour and get into the case (being smaller molecules than water molecules?). React with the lume in a hot environment for rapid darkening?
Happened to me as well, a 6306 with fresh gaskets and pressure test. No swimming, just a really sunny day. I left it inside for a couple of months and the lume reverted to the old state.
I had a similar thing with my 6139-6002, after a day in the sun the lume went a slightly darker shade, and after a few days returned to normal colour. A weird phenomenon I haven’t experienced on any new seikos, must be something to do with the old lume formulations. But again, it doesn’t happen to all of them.
Rob
Did it remain that way?
please define what you mean by, "I left it inside for a couple of months......" I guess I'm lucky, but I've worn many a watch on super hot/sunny days and have never experienced this phenomena. might it be a manufacturing plant thing akin to the daini 6217 lume color being different from that of its bretheren?
<* shark >>><
Discussion Starter #19
That's an interesting experiment to try. I'll put it away for a bit when I get home from this holiday and see what happens. I'm doubtful, but will be pleased if it works.
I have had similar experiences with recently sealed '77 6309-7040 and '79 7549-7010 examples. I don't have any pictures to share, but I noticed that their lume darkened slightly after wearing out in the summer sunshine/heat - no water involved. Although they didn't turn as dark/grey as your dial, both watch's lume reverted back to a paler color once stored back inside away from light for several days.
1 - 20 of 29 Posts
