The C300 is battery powered and it has anew cell- ive performed the full reset and zeroed all hands but when it comes to zero the hour hand it does not moveFirst thing, Full charge, Refer to the manual for any answers, Or have a look under the hood and get a visual, You probably have to get in there anyway.
Maybe your right John- the alarm buzzer arm is also missingDoes it have a separate coil or something ?
It's not that complicated but be prepared to spend more time on it than on mechanical movments as most parts including the baseplate is plastic. A complete replacement movement is about 60 pounds at cousins now so rebuilding the current movement is the way to go. Post a picture if possible.thank you - yes it’s a new project-
It might be a little too in-depth for me
I’ll look at siralans posts or maybe to to find a doner
If I do find one I may try to swap over the dial and hands
Thanks for the input
It’s a nice condition so I’d like to save it and they seem to be harder to come by
Lovely! Just out of curiosity, did this have battery leakage/corrosion when you removed the back? I repaired one for my instructor whose watch had tiny crystalised green muck on
