sorry about the double posting, thought get more response here Hi,guys.
I am having issue with this recently purchased watch - CITIZEN bu0003-02p.
everything seems working except so-called semi-perpetual calendar.
well, it meant to be semi-perpetual so I only need to adjust in leap year once every four years.
however it's not working at all and I need to adjust several times a year when the month is only 30days.
I have followed the instructions several times to reset it, but it's not improving at all.
Just wondering if I did anything wrong at all?
thanks in advance!
HTML:
If your caliber is 8730 or similar (check the case back), then you were misinformed about the capabilities of your watch. It has no ability to self-adjust for the 5 shorter months in the year- you must do so manually. If it makes you feel any better, most watches are like this!
(From the 8730 instruction manual, page 17:
② The day of month indicated by this watch follows a 31-day cycle.
To advance to the 1st of the next month after a short month (a month
having 30 days or February), pull out the crown to position 1 and turn
it to the left.)
