· Special Member
Ok its not actuially a BN000 but near as.
ive removed the bezel and retaining ring which appears to house the crystal + the chapter ring.
Any ideas how to seperate them?
Do I press the crystal through from the front and dislodge the chaper ring at the same time??
Pic of the crystal/chapter ring is from underneath the black is the bottom of the chapter ring.
The only gasket I can see is a thin nylon? white one going around the outise of the crystal
thanks
· Special Member
Well I'll answer my own question
It pushes from the back out of the front, the chapter ring stays in situ
Pretty simple so far- now the reverse once it's replacement arrives
