Hi all,
I've gotten stuck on a Citizen 4-095111 Y. It works, but the digits are too dim to see unless you really look closely. The battery is confirmed good at 1.5v. I removed and cleaned all the battery contact parts with no luck. Normally, I'd disassemble the module, but holly molly, the crown mechanism is complex on this one, and I'm not even sure how to take it out, much less put it back together. I don't think this one has ever been worked on before and there's no corrosion anywhere inside, so I'd bet the circuits are all good. It may be the zebra strips or LCD contacts need cleaning? Usually that's an easy fix, but not on this watch! Could it be a bad component?
Any advice on what to try next? How does the crown come out? Thanks!
