1 - 7 of 7 Posts
Does anybody have a casing guide that covers a 5J22-0C80? Or more specifically, any info on how to remove the crystal? Many thanks.
Here's a pic of the watch.
Cheers, Sam.
OK... I've given pushing the crystal from the inside, outwards a good go. It's not moved at all. If I push harder I think it will break.
Maybe the metal ring around the crystal on the outside of the case is a bezel that has to be removed first? No sign of a notch for removal tool though...
· Researcher
It could well sit in a bezel ring which has to be pressed out from behind, I can't see from your pic if there's a separate ring or if it's moulded into the case to look like it.
I gave it a good long soak session in the ultrasonic, then back on the crystal press. One good push (from behind) and it popped out. There is no bezel. Success!
Many thanks for your help. :sign0098:
Discussion Starter · #7 · (Edited)
Thanks Jim, I've got a new xtal and full set of gaskets ready to go, from Cousins.
Just for the record
290P34JZ0C GLASS
86565320 GLASS GASKET
FE308BAD2 GASKET, CASEBACK
FE308BAD21 GASKET CASEBACK
AD006BAD1 CROWN GASKET
G39082 GENERIC GASKET (multi pack, same as AD006BAD1)
302324X MT920 CAPACITOR
xtal according to JB: 290P34JZ0C
1 - 7 of 7 Posts
