A couple of months ago, I took my watch to a shop in Tokyo to get regulated. Afterward, it ran +1 second a day. Needless to say, I was ecstatic. However, last week I noticed a problem when cleaning the grime around the caseback (see attached picture). Apparently, the shop pinched the gasket when replacing the caseback. I then took it to a Bic Camera to get a new gasket. Lost-in-translation adventures ensued. I wanted to get a new gasket installed, but I don't think that made it through the language barrier. When I got the watch back, the employee made it clear to me that the watch was no longer waterproof. I saw their pressure tester. Now I have a watch with an unknown gasket situation. I have tried to locate the gasket number, but to no avail. The caseback number is 6R21-00M0. The watch is SBGA011. The case is identical to SDGC001/3/7/9, as far as I can tell.
If anyone knows which Seiko gasket number is correct for my watch, I'd really appreciate the info. Thanks so much.
I looked around based on your case number (how parts are ordered), but it must be too new for all the places I have access to. If you had case references for the SDGC models you mentioned (xxxx-xxxx), then I could try looking under those. No guarantee it would be the same though, but it might be a start. Maybe a local watchmaker could measure the existing gasket and case dimensions and fit a generic gasket until the genuine can be found?
Hey if he had the dimensions another one might work too...i have never seen that model...that stinks that damage it and did not repair it..so very sorry...
