1 - 19 of 19 Posts
hello guys!
does anyone know where i can find , or have installed a specific type of bracelet on a citizen aqualand JP2000?
sfaik this is very hard to find,
and been looking for a compatible
i want it to have curved end links, i dont mind working on them a little to fit nicely
any advise?
This is the Original Bracelet for it, but its scarce to come around.
to find a compatible one you have to get a ....(24mm ) Bracelet to start with. I have three of the originals, but had to rally search to get them.
Once you find one it can be fitted with no problems, but the
" main-link " has to be a tight one or it will eat away the watch head,
it can not be loose at all.
No Problem glad to help if Possible anytime.
That's a nice one ..........
BUT : You might have to ( Spread Wider) that to fit into the .... " Case Lug ".
When buying for a Aqualand and especially for a watch that has a thick
case area where the last link snugs to the case one should make sure that it has the fit for it. Look at your
watch and measure the thickness od the Upper and Lower lug are that the Bracelet will slip on too.
Ask the seller if the one you like has that spacing for sure.
I have found that like those ........... ( Citizens Blue Angels and some
others like chronographs ), have a positive locking to them. for the
Bracelets.
___________________________________________________
Do you see how the Bracelet Snugs onto the case and the Bracelet tabs are fitted ?
( First Two pictures ...... " Those Tabs ". )
That's the most important part of the matching to the watch head.
______________________________________________________
Do you see the First Aqualand picture where the case back is by the Lug, that's the problem
area sometimes with many Bracelets.
Solid end links just don't cut it some times , can not open them up to fit.
Picture Three :
If there is no space it wont fit right. It has to go onto the watch Head rim over and below the Lug.
( Do you see that one Third picture ? )
(Third picture it this smaller .... Citizens Quartz chrono. 200m)
Many are just to different I have found out.
Some are just not Bendable.
Hope this helps you a little.
If you like a good rubber strap this one is great, and I
don't like straps, until I got this one. The one on the watch.
Since I have it I have noticed it does not collect perspiration
onto it and not sticky too.
I think the website is called............ ( " A Time for Time " ),
or something like that.
thank you!
is this boneto cinturini?
Yes I think that's what it is called. Its a little thick, but it
fits real good for me. I like it because it does not collect
physical perspiration, and its washable. It is said it is
scented also.
I do not like at all Straps, but I enjoy this one very much
because of its fitting.
Discussion Starter · #10 ·
scented also.
i had one like this Boneto
you re absolutely right
it is a great strap for the value
i might get another one
barryw ,
That is good to know that some where there are more, you lucky you
...... Hahahaha.
They are very hard to find, and I only need one to complete mine
so I continually look for one to be found yet.
So always liked them but dis-like rubber straps completely.
Discussion Starter · #13 ·
I found out today from a friend that the bracelet from the aqualand I
Will not fit on aqualand II (jp2000/2004)
Anyone can verify that ?
That is also true and it can be very mis-leading when buying for them.
My apologies for not mentioning it Sir. There is a case head difference where the main
link goes against it.
Discussion Starter · #15 ·
Thank you very much for that :)
too bad,cause i was willing to make an offer to Barry :undecided:
best
G
1 - 19 of 19 Posts
