1 - 8 of 8 Posts
Hi All,
Are the Seiko 6138-3000, -3002, -3003, -3005 and -3009 the same "size" but only of different case design ?
Sometimes I see the 6138-3009 listed as "Jumbo", but I believe it is diameter as the other models.
Thank you !
Researcher
Not quite the same case, The 3000 and the 3002 are different but I think the width is the same.
the lugs are different and they use different crystal fixing rings,
seikola
Very interesting information, so if what you say is correct - then the whole Seiko region code hypothesis is now blown away.
It's quite strange that this seems to be the (or one of the) only exceptions to the rule where the case itself is different from another, with ostensibly the same case code.
Curiouser and curiouser.
1 - 8 of 8 Posts
