I have a 7s26-0500 case laying around and i am going to put a 6r15 dial on it, without the day function.
Therefore i am looking for a replacement crystal with magnification. The original seiko glass has the code 290P05HN03.
Is it safe to assume that the width is 29.0mm and the height 0.5mm?
If someone knows, it would be a big help!
Thanks :grin:
29mm is correct. There is no way to know, from the part number, the thickness. You will have to take the crystal out and measure it.
Somewhere on this site, is a crystal code document. I can never find it when I need it.
Thanks man! Will try to find it, couln't find it with the search :eek:hmy:
