1 - 14 of 14 Posts
Hi all,
Just nearly popped on a 7548/6309 crystal. However did a bit of research in the archives and it seems I need a slightly different one . Something to do with the bevel edge. So would anybody have one or know of a source /lead on a 320W48GA00.
Thanks in advance. Tony
Hi
Bry here does a really good repro for a 7548/6309 that has a suitable bevel for the 7c43 too. I've used one and it's great.
Unless you need a genuine crystal try PMing bry1975
Gavin
Sent from my Pixel 3a XL using Tapatalk
Thanks Gavin , as it happens just ordered 4 crystals from Bry. Are you saying that you have successfully fitted one of his crystal on a 7C43. Others say the genuine/ copy ones for 7548/6309s don't fit. Cheers Tony
A 6309 320W34G00 or any 1-1 copie will work fine. It’s been a non issue for me, I’ve used one of Bry’s on 7c43. Also genuine 320w34G00 on 7548-7010 which came with the same crystal as 7c43-7010/09.
Definitely used one of Brys recent crystals with a 7c43 with the screw down retaining ring. At the time I sent the case to him to check all was good with profiles and the rotating ring clearance etc
Cheers
Discussion Starter #9
Than
Cheers
Thanks for the reply,its gives me confidence on a result. I await the delivery. cheers T
1 - 14 of 14 Posts
