I'm trying to replace the crystal in my seahorse (and give the case a good clean/polish).
Having double checked the crystal won't just pop out with a crystal lift, I have tried to remove the bezel but it appears to be stuck fast! Probably because it dates from 1967 and at some point looks like there has been some water damage that has ruined the dial (however, the workings appear to be lovely and clean). There is a very thin brown ring of oxidisation (rust) that is around the inside of the case where it meets the crystal and also at the point where the stem is attached to the crown (which has SW imprinted into it - so ideally I'm looking to save it).
I'm presuming it's the oxidisation that's causing the sticking (and probably the fact it's 43 years old) so would a spray of WD40 help (or would there be any adverse effects of using it)?
Is there another product I should use to clean up the rust from around the end of the stem to prevent it getting any worse?
Or should I use an alternative case that'll need a bit more work to it to get it nice and clean - I have a couple of other 8980's that I bought in 'blurry ebay picture lottery' in the hope of getting a replacement dial?
Thanks for your help.
Hi,
Could you post some pictures of the watch, bezel, and the rust you are seeing ? That would certainly help determine what the problem is and the best way to remove the crystal.
Okay, gave this another go last night and after soaking the case in WD40 for a while, I placed a nylon from my crystal press inside the case and after a couple of good taps with a jeweller's hammer, everything came apart no problem.
I've attached some photos of the rust I mentioned, along with some other pics. I've purchased some rust remover, do you think it's worth using it before placing the crown/stem/case, etc in the ultrasonic cleaner, or do you think the oxidisation is too far gone?
I admire your courage!
Yes, that stem seems quite rusted, so I would think that a rust remover for the case and bezel would be a good thing.
Are you going to get the movement itself serviced?
Courage = foolishness you mean ;)
To be honest, having seen the state of it, it's going to be more a 'tinkering' watch. I'm hoping the rust can be removed from the stem so it's perfectly usable in another seahorse (as it has SW on the end of the crown), and if the case can be cleaned up, it'll be a good test subject to try out my case polishing skills.
I also enjoyed taking the photos and when I have time will photograph a step-by-step strip down so I'll be able work out how it goes back together :)
· Banned
You will enjoy working on the 66 caliber. It is pretty forgiving and even if you lose your pictures, it's pretty easy to reassemble :)
Discussion Starter · #8 ·
I cleaned up the rust last night then gave the case, bezel and stem/crown a blast in the ultrasonic cleaner. I wouldn't say the rust has completely gone from the stem but it certainly looks better. Would it be wise to give it another blast with the rust remover and US again?
Question - once stuff starts to rust, is that it - game over, or will it be fine?
I'm looking forward to getting the time to take this watch apart! :)
You cannot reverse any damage caused by rust but you can probably stop any more damage..
Most of us here are pretty much constantly aware of whats on our wrist and will automatically remove watches before doing the dishes hosing down the Harley.
If any water gets near the watch AT ALL... we will at the very least remove the movement and let it dry out thoroughly. If this does not describe you, rest assured .. it will soon.
You can remove the bezel and address the rust, a thin blade will do the trick. Having said that, the bezel (or crystal retaining ring) is quite thin and can break if the replacement crystal is not a correct fit. If not too bad I might just try the rust remover stuff...but I feel that the thought of all that rust potentially spreading and eating into that nice stainless steel would be constantly bugging me and I would remove the bezel in the end anyway.
All the best
Anil
