Hi There ;D
As John pointed out, the minute hash marks are going to be diffecult to reproduce by hand, I would be hard pressed to suggest a human hand could do a job that would be undetectable to the naked eye. This you may have to live with, whether you get them redone by hand or not. Much of it depends on what acceptable to you.
As far as the Emblem goes. This particular
"Matt" finished emblem is very rare, only being used on the 6105 divers and some 7a28 (as pointed out by Noah Riley some time ago). This is complicated by the fact that these emblems do not always come off perfectly, usually when you see one bent, its because someone may have tried removing the emblem, and it got damaged, they are extremely fragile and once bent, you simply cant bend them back to the point the it hides the bend.
Baring being able to find either or these two watches at a price that makes tearing the emblem off the dial worth it, you can still change the emblem, but you`ll be forced to use either a bright silver emblem, or the gold emblems found on the rest of the Seiko line.
This of course may give you an oppertunity to
Bling it up a bit, if you like,
[img]
Randall
[/quote]
