1 - 15 of 15 Posts
Hi,
Would appreciate it some expert in this forum can confirm if Seiko crystal part number 325W14GN can fit the 6159-7001 model? If you look at the attached photo, there is a metal band that goes around the base of the crystal. Will that affect the installation? So is this the correct part or should it be the 325W14GA?
Hope someone can confirm that 325W14GN with the metal band will fit the 6159-7001 watch before I purchase it. Thank you.
BR
Prime88
Thanks guys. That helps to explain why I find the metal ring kinda weird in the first place. So the search goes on for a NOS crystal. BTW, any leads to buy one at not so crazy price? Thanks.
We seem to be spoiled for choice with the 325W14GN00, strange really for a pretty rare model.
I gave Jonathan a little assistance producing a replica( i loaned him a OEM crystal) and I also have a sapphire 325W14GN00 :)
Discussion Starter · #9 · (Edited)
You guys are great. So much knowledge to share.
From the attached parts spec posted by The TigerUK, it would mean that the GA model is exactly the same as the GN model except for the anti fogging coating.
Cannop, thanks for the lead regarding other alternative parts and I will keep a lookout for it.
One more question. Currently someone is selling a 325W16GA crystal. So based on the spec code information, the middle number is just a serial number for production purpose. So does that mean the 325W16GA will be exact dimension as the 325W14GA/GN? Then the difference will be?? If it is exact dimension, then can I use the 325W16GA for the 6159-7001?
Thank you.
Researcher
Thank you.
The only guarantee would be the diameter being the same.
Discussion Starter · #13 · (Edited)
Hi Duncan,
From photos that I sourced from the internet, it seems that 325W14GA has a non frosted bevel that is similar to the 325W14GN. However as mentioned by you before, the 325W26HB0A has a frosted bevel. Is this fact correct?
Thank you.
1 - 15 of 15 Posts
