1 - 8 of 8 Posts
Hello all,
Bracelet lug pin on my Sportura is worn out (the other one snapped actually! :oops:) and I am having a hard time finding the proper replacement. Does anyone have any idea where to get it? I found 20mm ones used on Monster bracelet links, but this one is 23mm long. Thanks!
449550
Hi, could you provide a movement/casecode number
xxxx-xxxx to help us help you!
Thanks, this will probably produce more useful results than "Seiko 23mm collar pin". (y)
Well...it appears those are not available anywhere so I might need to improvise. :-/ I found Seiko 81604259 ones on Ebay, I believe those should work too.
These are available from Seiko parts houses, about £2 each UK, maybe a dealer could order from Seiko. You could try an email to Seiko service, they might help.
Discussion Starter #8
Thanks, that was my next step. Hopefully they will not say it has been long discontinued, but can't say I would be surprised if they do.
Frustrating when something that you'd expect to be a trivial problem turns into a headache.
1 - 8 of 8 Posts
