L
Librarian3
·Guest
Authored by NaviGator
Seiko 5 Sports 6119 6053
Hello,
This is my first watch review, so i'll gladly stick to Isthmus' template.
Brand
Seiko
Model Number
Official or unofficial Nickname
I'm not aware of any nickname, but if i would be asked to name it, i would call it the "Seiko Sailor". Why will become clear when we get to the bezel.
Overview
I found this Seiko on the net. The pictures on the website were very vague, but after some trial and error i could reconstruct the model nr and was able to track a similar watch on the 'bay. This allowed me to see what it really looked like. It immediately appealed to me and as the seller didn't live that far away, i went over to her place to check out the watch.
It turned out to be near mint - exept for some extremely minor spotting on the hour hand that is only visible under a certain angle - so i bought it, as the asking price was very reasonable.
Movement
- 6119 automatic wind movement
- 21 jewels
- non hacking
- non hand winding
- quickset day/date (quickset of the day by pressing the crown, date correction by winding the crown)
- not yet chrono tested but apparently running ever so slightly slow
Case review
I don't know what a case like this would be called. It has a very particular shape, which i guess you either like or you don't. I do.
Width (L to R): 40mm
Diagonal: 54mm
Height (lug to lug): 45mm
Total Thickness: 11mm
Bezel: 41mm
The case back reads:
"Seiko"
"Stainless Steel 6119 - 6053 Water Resistant"
"278832"
"Japan"
The crown (at 4) is nearly completely hidden in the case.
Dial and hands
- Silver dial
- Silver hour & minute hands with white inlay (maybe luminescent in the past, but not anymore)
- orange second hand
- white hour markers
- in very small font it says "Japan 6119 -6050s
crystal
The crystal is flawless. No scratches visible. It is slightly domed, starting 1mm above the bezel.
bracelet/strap
Seiko bracelet in very good condition, but i'm not 100% sure it belongs to this watch. I have read somewhere that the original bracelets on this kind of case would widen just below the lugs. The clasp is signed Seiko, in bas-relief. The inside of the clasp is marked with "STL Stelux" and "All stainles steel".
bezel
It is a double bezel watch:
- inner bi-directional plastic bezel, under the crystal, showing 12 hours, 4 in blue, the rest in green. This bezel is moved by turning the crown when fully pushed in.
- outer bi-directional bezel, showing 60 minutes:
The watch is Water Resist up to 70m, quite a strange depth, but regular for the 6119's.
Closing opinion
It's not a regular looking watch, but i like the style a lot. I'll wear it, but only if i'm quite sure it's safe to do so. I'd like to keep it looking the way it does now.
This was the first Seiko i bought. Since i have this one, i've added 5 more, of which 2 are still in the mail...
Hello,
Brand
Seiko
Model Number
Overview
Movement
- 21 jewels
- non hacking
- non hand winding
Case review
Diagonal: 54mm
Bezel: 41mm
"Seiko"
"278832"
"Japan"
Dial and hands
- Silver dial
crystal
bracelet/strap
bezel
0-10: from warning sign to start sign of a sailing regatta
11-20: 10 minutes counted from start sign (if not past starting line after this, you are counted as a non starter)
21-60: to complete 1hr
Closing opinion
